Results 1 to 7 of 7
Thread: changing to 05 fans...do I have everything?
    May 2005
    I got some e-fans off of a 05 Silverado for my 01. I also got the 34" radiator, 145 amp alternator, and the nelson harness....what else do I need? Do I need to change the alternator belt? Thanks for your help.
    speedy
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
    Apr 2005
    You also need to activate the PCM to control it.
    Gone, but not forgotten!
    Forgot the 12 pack of brewskis.
    May 2005
    <div class='quotetop'>QUOTE(SCIV &#064; Jan 12 2007, 04&#58;35 PM) [snapback]79455[/snapback]</div>
    I&#39;ve got Nelson tune pcm, forgot to mention that.
    Will the 05 fan harness plug into the 01? I don&#39;t think it will but not sure. Anyone know?
    I&#39;ve got a 12 pack of Root beer since I gave up drinking years ago.
    Yeah, whatever your poison you have to stay hydrated.
    Mar 2006
    I was also curious if the stock 05&#39; harness is a plug and play for the earlier models. Any ideas?
    Mar 2006
    Did you just use the required fan portion or the complete front wire harness? I was wondering if the complete front wire harness can be swapped?
    Thanks,
    Dave
