Results 1 to 5 of 5
Thread: a couple of questions ???
    Jan 2007
    i saw some post about problems with e-fans and the wiring should i expect the same, and will pcm need to be worked on so they could work with the wiring harness?
    and i also have an 2003 dash cluster i guess thats what its called, well the thing with all the guages well it goes up to 120 and mine is 2001 only goes to 100, can i swap them out easily or should i not even try i'm pretty sure i seen acouple of older truck with that setup.
    2001 silverado 4x4 ext. cab, 2006 front end, cold air intake, msd spark wires, flow master, hp tuning, 20" bbs rims, 2" drop in back, e-fans
    http://i134.photobucket.com/albums/q.../jaxbigger.jpg
    Oct 2005
    drinking your alcohol
    well with my fans, i have a nelson tune and should already be programed in...
    same kind of deal with the new cluster, you have to get it calibrated/programed to work with your truck
    DamnYankee: my nana failed
    Jun 2005
    Round Rock
    When I had my '01 Silv, I sent off for the dash and they programmed the mileage into it. They now send a sticker that you are supoposed to put somewhere so other know that your mileage may not be correct.
    To run a Nelson harnesss or another harness that uses the PCM pin you will have to have the pin programmed . Some people do not like to hear the fans on high when the A/C compressor turns on. I did not hear it that much nor did I care when I had the '01 Silvy.
    08 HHR SS
    Jan 2007
    do yall know if the pcm pins can be programed by hp tune and also the guages, i think i know somebody to
    do the gauges to set the milage but if i just swap them out right now will they work or even connect.
    Apr 2003
    Mansfield, Texas, USA
    Cool
    Last I looked the '03 cluster won't fit the '02 down trucks.
