Results 1 to 10 of 10
Thread: New member
    Jan 2007
    I have a 2006 WT ext cab with the 5.3 y pipe dual exhasut with flowmater 40 a airraid throttle body spacer and hypertech 3 best time turned was a 15.86 in the quater besides a intake what else should i do id like to keep my truck with a NA motor. wanting to turn at least 14s by this spring when the seanson starts again. from ohio if that matters thanks guys
    Welcome
    You need a cam, headers and tune to get into the 14s. That should be a nice start.
    Jan 2007
    any recemdations on cams or tunes in ohio
    There is alot of different cam specs that fit different needs or wants, it just depends on the direction you are going on. As for tuners im clueless up in Ohio. But you could always do a mail order tune from allen nelson.
    Welcome BTW
    What he said!
    Oct 2005
    drinking your alcohol
    yep what they said.... i was running 15.3-.5 all day long....
    went and got me a cam kit from Texas-Speed : comp cams 220/220 581/581 112+2 (came with dual springs, retainers, pushrods and cam)
    got some long tube Pacesetters with the Off road Y
    then got a tune from Allen Nelson
    first time out pulled a 14.8x ...... but i have to have some of the worst 60ft times on the planet...
    if i would have just a posi unit i could be in mid-low 14's no problem.... if i got taller gears and posi and stall for my trans, i can alomost feel 13's....
    this is where im at and sounds like your in the same boat i started in...
    DamnYankee: my nana failed
    Feb 2005
    San Antonio Tx
    welcome
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    May 2006
    Waco TX
    Well the first thing I would do is throw the hypercrap away and get a custon tune from Nelson. Then Longtube headers, Cam, Stall. The will get you to the 14's easy.
    Jun 2004
    george west texas
    yep..what they said and welcome to the site...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Everyone has a photographic memory, some just don't have film!
