Results 1 to 10 of 13
Thread: BBK THROTTLE BODIES
    Jan 2006
    I HAVE A BBK 80MM TB AND HAVE HAD NOTHING BUT PROBLEMS WITH IT. TOOK THE TRUCK TO THE TRACK AND PRESSED THE PEDAL TO THE FLOOR AND THE LIP MOVED ON THE SHAFT. IDLED HIGH BACK TO THE PITS AND I PULLED THE LINKAGE TOWARD THE FRONT OF THE TRUCK TO GET IT TO IDLE CORRECTLY. I CANNOT GET IT TO IDLE WORTH A CRAP. RED I THINK IT MAY HAVE A LEAK SOMEWHERE. ANYWAYS I AM GOING BACK TO THE STOCK UNIT FOR NOW. I RAN THE BBK ON THE MOTOR BEFORE THE TURBO AND SEEN NO HP GAIN, BUT DID LOOSE TORQUE DOWN ON THE BTTM END. THE STOCK TB GAVE ME A LOT MORE ON THE BTTM END. I GUESS I NEED THAT RIGHT NOW SINCE MY 60' SUCK.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Nov 2005
    ohio
    STICK WITH THE STOCKER! i THINK THE ONLY PEOPLE WHO BENEFIT FROM A LARGER THROTTLE BODY ARE THE RADIX GUYS.
    get Billy to sell you a Shaner TB. Those things are nice.
    Jan 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Dec 22 2006, 08&#58;56 AM) [snapback]77083[/snapback]</div>
    I MAY DO THAT. BBK SUCKS IN MY OPINION, BUT THAT&#39;S JUST MY OPINION.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Apr 2003
    Mansfield, Texas, USA
    If it&#39;s a mech TB, I&#39;d be interested...
    Jan 2006
    <div class='quotetop'>QUOTE(Hit Man X &#064; Jan 11 2007, 02&#58;10 AM) [snapback]79236[/snapback]</div>
    I WILL SELL IT TO YOU CHEAP.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Nov 2006
    Plano, TX
    I&#39;ve never heard anyone do well with the BBK 80MM unit...
    Mr. P.
    Jan 2005
    Humble/Houston TX
    <div class='quotetop'>QUOTE(Mister P &#064; Jan 11 2007, 03&#58;12 AM) [snapback]79246[/snapback]</div>
    Mr. P.
    search up V8. he does 12.5&#39;s all motor in his scsb 5.3 with his bbk. i have a shaners and like it alot.
    old mod list: H/C/I/N/E/G 408
    Jan 2007
    Mr. P.
    i have the 80mm BBK throttle body on mine and my truck is running great. 13.8 on street tires no stall....however i bought my truck with the TB already and tuned and that tune i had at the time wasnt tuned right and made the TB randomly close at high speeds causing my truck to bog down really ugly. I changed tuner and he got the TB working right and strong. So its all in the tune if you want to get a bbk TB function right.
    12.82@103.82mph w/1.78 60ft
    TUNED BY DAN
    Nov 2006
    Plano, TX
    <div class='quotetop'>QUOTE(lablackpearl &#064; Jan 11 2007, 03&#58;14 PM) [snapback]79304[/snapback]</div>
    Do you have a higher flow MAF as well? Or are you still using the stock MAF?
