Thread: Wiring problems on LQ9 swap into '99 Sierra
    Apr 2006
    Ok, so I've finally got the motor in, and I'm working on getting everything hooked up, but I've hit a few snags. The motor is out of an '04 Siverado SS, and it's going into my '99 Sierra. I'm having problems with the connections under the fuse block. There are 3 connections on the old harness, one wrapped with purple tape, one with green tape, and one unwrapped 3 pin connector. The new harness only has the purple and green connectors, and the purple one has a different connector, and more wires. Any ideas? I'm assuming I'm just going to have to get pin-outs for both motors, and swap connectors and pins around until they match. Anybody had to do this before?
    '99 GMC RCSB
    3" Body lift, 4" Rancho lift, Fox shocks
    36" BFG All-terrains
    LQ9 6.0L swap, gt2-3 cam, longtubes, LS1 fans, Nelson Performance tune
    4.8 gears/Eaton posi
    Built 4l65e
    Custom paint, roll pan, filled tail lights, relocated tail gate handle
    Future mods:
    Boost!!
    I've never done the swap but wonder why you didn't use the stock 99 harness on the LQ swap. Was something different? What engine was in it before?
    Apr 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Dec 17 2006, 05&#58;27 PM) [snapback]76583[/snapback]</div>
    I&#39;ve never done the swap but wonder why you didn&#39;t use the stock 99 harness on the LQ swap. Was something different? What engine was in it before?
    The &#39;99 harness was for a Vortec 4.3L. I suppose I should&#39;ve mentioned that in the post.
    '99 GMC RCSB
    Built 4l65e
    Future mods:
    Boost!!
    Yeah, that helps.
    <div class='quotetop'>QUOTE(tenshikurai &#064; Dec 17 2006, 08&#58;11 PM) [snapback]76579[/snapback]</div>
    Ok, so I&#39;ve finally got the motor in, and I&#39;m working on getting everything hooked up, but I&#39;ve hit a few snags. The motor is out of an &#39;04 Siverado SS, and it&#39;s going into my &#39;99 Sierra. I&#39;m having problems with the connections under the fuse block. There are 3 connections on the old harness, one wrapped with purple tape, one with green tape, and one unwrapped 3 pin connector. The new harness only has the purple and green connectors, and the purple one has a different connector, and more wires. Any ideas? I&#39;m assuming I&#39;m just going to have to get pin-outs for both motors, and swap connectors and pins around until they match. Anybody had to do this before?
    the fuse block for 99-02 trucks is different than the 03-06 models.
    schematically different pinouts and physically different.
    youll have to repin your fuse block connector with the new wiring.
    upgrading to the 03-06 fuse block will complicate your mission, as
    the interior pinout for the 99-02 isnt as complete as the 03-06.
    especially the v6 version as it uses the older black vortec computer.
    airdeano
    Oct 2006
    could somebody explain each connector and what they connect to
    2-PCM
    what are the color ones that connect near the PCM???
