Results 1 to 10 of 10
Thread: Is there a Torque Converter Install "HOW TO"
    Aug 2005
    Spring, Texas
    I am fixing to get my cam put in and i want to put the TCI 3000 in, but i would like to have step by step instructions, so i won't miss a step.
    Anyone know where to find some instructions?
    Thanks,
    Brent
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Aug 2005
    Houston,Texas
    I used a haynes manual from the auto parts store, fill tc before install,remove three bolts( tc to flexplate) 8 bolts around tranny, all elec. connections,exh. , driveshaft, and crossmember and a tranny jack helps alot . good luck
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    Aug 2005
    Spring, Texas
    thanks
    Jun 2005
    Round Rock
    Make sure the TC is as far on the shaft as possible and then some..... when you butt the tranny up to the engine you should have to pull the TC forward to the flex plate. just my
    08 HHR SS
    Aug 2006
    Willis, TX
    <div class='quotetop'>QUOTE(jethro_3 &#064; Nov 23 2006, 07&#58;13 AM) [snapback]74339[/snapback]</div>
    AAAAman. Very important&#33; When I was 16, building me first hotrod, I didn&#39;d have my TQ all the way on the input-shaft. As I was tighting the bell-housing bolts sucking it up to the back of the engine I ended up breaking a big piece of of the bell-housing. On the old Turbo 350&#39;s the TQ would go on the input shaft two clicks as you rotated it back and forth.
    Introligator
    05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
    Facebook
    Search the internet. There are quite a few guides for transmission removal and installations.
    San Marcos Texas
    Make sure you get a quart of tranny fluid into the new converter before you install it. Lube the converter shaft before you install it. Use blue locktite on the converter bolts.
    To be sure you have the convertor in all the way before installing the transmission, measure the distance from the face of the flywheel/flexplate to the engine block and then measure the distance from the bellhousing to the convertor bolts. The transmission measurement should be greater by at least 1/8".
    Oct 2006
    OKC, Oklahoma
    On a 4L60E the TC will go back 3 "clicks" and it should sit back about 1/2-3/4 from the front of the TC to the front of the bell housing. Also there are 3 TC bolts, and 2 different types Alan heads, or 15 mm. If you have the Alan heads, replace them with 15 mm
    2004 Chevy/Regency RST, 6.0L LQ4, custom built NV MG-5 tranny by local Tranny Guru, Hurst Shifter, K&N FIPK, stock Regnecy Exhaust, 3.73 gears w/ Eaton Locker, and the Magnacharger huffer topping it off w/ stock pulley... for now
    Looking to meet people w/ LS1 trucks in the OKC area PM me
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(daredevil350 &#064; Nov 29 2006, 03&#58;41 PM) [snapback]74883[/snapback]</div>
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMEN&#33;
