Results 1 to 5 of 5
Thread: Pulling the starter....
    Jun 2005
    Ok....I have got to pull the starter to get to the crank sensor and check it out. Anyone have any tips or tricks to do the job? Special tools required? If I pull it, do any parts need to be replaced in the process; shims, spacers, etc? I'm assuming that if I replaced it I'll need to do a CASE learn afterwards?
    '02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
    Nothing special I know of, just a 15mm socket, extension and ratchet required.
    May 2006
    Waco TX
    I believe it is just 2 bolts, on the back right of the motor front of tranny. Just be sure you get the teeth lined up right when you reistall it.
    Huh?
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Nov 16 2006, 01&#58;52 PM) [snapback]73744[/snapback]</div>
    I believe it is just 2 bolts, on the back right of the motor front of tranny. Just be sure you get the teeth lined up right when you reistall it. [/b]
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Nov 16 2006, 01&#58;54 PM) [snapback]73745[/snapback]</div>
    Huh? [/b]
    Now that&#39;s funny right there, I tell you what...... Who said there&#39;s no comedy on this channel?
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
