check your fuel pump relay, when there is oil pressure the fuel pump starts to work through the switch. install a fuel pressure gauge and check fuel pressure when cold. if it is low or none, try to crank the engine over and watch the pressure, if after it get oil pressure the fuel pressure starts to rise, keep the engine cranking until it starts (if it will). it takes way more fuel pressure to start than it does to run.
