Results 1 to 9 of 9
Thread: Motoblue wire set
    Has anyone tried these?? http://www.rpmoutlet.com/gmsuvaspa.htm
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Jul 2005
    Loganville, GA
    I have the MSD 8.5mm Superconduct wires and they are .5 mm bigger than the ones on that website and ill tell you right now i didnt see 10-15 hp, but hey they look cool
    Apr 2005
    Those sound like the exact gains of those Granatelli wires. I would have to call BS on that one.
    Gone, but not forgotten!
    <div class='quotetop'>QUOTE(SCIV &#064; Oct 30 2006, 01&#58;08 PM) [snapback]71656[/snapback]</div>
    yeah, thats what i was thinking.
    Jul 2006
    College Station, TX
    why dont you do this. Take an ohm tester and test your wires. When i test mine tested out at .8 ohms. Dont waster your money on wires. I highly doubt that your wires are your bottle neck
    2004 EXC Silverado 6.2L
    Mods:
    One of my wires is torn, so i&#39;m going to have to buy new ones. So, i should just go with the MSD?? Just curious, when my truck shifts to the 3rd gear, it sometimes backfires, could this be the problem?? BTW, this only happens in tow/haul mode.
    Apr 2005
    If it is torn, then I would replace it/them.
    Your maf sensor hasn&#39;t not been descreened, has it?
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Oct 30 2006, 08&#58;55 PM) [snapback]71699[/snapback]</div>
    Nope
