View Poll Results: Which has greatest performance increase?
Voters
9. You may not vote on this poll
  • Underdrive Pulleys
    1 11.11%
  • Ported stock throttle body
    5 55.56%
  • Exhaust Cutout
    3 33.33%
Results 1 to 10 of 13
Thread: Which would your next choice be?
    Mar 2006
    Mesquite
    Again, please post the reason for your choise AND if you have a better idea of what to spend it on, let me know...
    Ported TB! What could it hurt?
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Sep 16 2006, 03&#58;53 PM) [snapback]65356[/snapback]</div>
    Ported TB&#33; What could it hurt?
    Well the results are in - 100% for ported throttle body&#33;
    Of course Greg is the only vote...
    well i voted for cutout, but i mean i would only use that for the strip. and yada yada yada, the ported TB is probably better anyway.
    Jun 2004
    george west texas
    well with a couple of hunnad to spend and you want the most bang for the buck would be a used kit...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Oct 2005
    Houston, Tx
    they are all good..lol
    Jul 2006
    College Station, TX
    i heard that gm has come out with a 90mm electronic throttle body with a sick intake manifold, along with 38# injectors and fuel rails and even heads. The heads flow 300cfm. I was told the heads were about 375 and you had to by the other which is about 500.
    2004 EXC Silverado 6.2L
    Mods:
    Must be thinking of the L92 heads which require 2 at &#036;375+ each, &#036;500 intake which is complete with fuel rails, injectors and throttle body(electronic), 8 intake rockers and 8 exhaust rockers(about &#036;25 each x 16), not all the same, rocker bases and new pushrods(&#036;180?). I don&#39;t know about valve covers but the entire package is going to be sweet when it becomes available as a kit&#33;
    Jan 2006
    Damn it Yankee just set aside 6 hrs next weekend and port that TB yourself&#33; It&#39;s easy and basically free and the results are noticeable. I put u/d pulleys on my v6 and couldn&#39;t tell much difference and I doubt youd feel much with a cut out either. You will definitely notice the difference with the ported TB. I have seen proven 7-11 hp gains from this mod.
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60&#39;] &#39;98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes &#39;98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,&#33;EGR,&#33;cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73&#39;s w/Auburn posi; Eclipse CD, Rockford 6 1/2&#39;s, Memphis 12&#39;s, Punch 200 ix, Punch 500x
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(motoxlifer &#064; Sep 17 2006, 08&#58;58 PM) [snapback]65476[/snapback]</div>
    I&#39;m not a bit interested in doing it. I&#39;d rather just pay the cash and get one from someone who has done them before rather than spend the time and possibly mess it up. It&#39;s only &#036;150. That&#39;s worth my time, to me anyway.
    Thanks for the numbers though. Hey, if I get 7-11 hp, that&#39;s 7-11 hp (cheaper than an intake for about the same gains).
    Thanks Moto.
