Results 1 to 8 of 8
Thread: Hughes Deep Trans Pan will not fit?
    Today I took my truck to the transmission shop to have all my goodies installed (HD2 shift kit, servos, etc) I had a new Hughes deep pan in the mix and the guy at the trans shop said it would not fit do to clearance issues with the exhaust. Anyone else have trouble putting one of these pans on? I can't return it because it is opened. Should I try a different trans shop?
    Thanks,
    Scott
    Aug 2005
    St. Anthony, Indiana
    Is your truck 2x4 or 4x4?
    <div class='quotetop'>QUOTE(foggy &#064; Sep 6 2006, 08&#58;03 PM) [snapback]64214[/snapback]</div>
    2WD
    Jun 2005
    Behind enemy lines in Kommiefornia.
    This is strange, I had a Hughes deep pan on my 60E before I converted to the 80E.
    I had no clearance issues.
    Me thinks a second opinion is in order here.
    2000 Silverado ECSB, 5.3L, 7" CST/3" PA lift, Hanneman &#39;glass fenders & bedsides, Currie Dana 60 W/ Detroit Locker, 4.56:1 gears , Willwood Dynalite Pro 4 piston rear brakes, Bowtie Overdrives 4L80E, Nelson Tune & Fan Harness, Harland-Sharp 1.8 Roller Rockers, 2200RPM Converter, Mezerie electric water pump, K&N FIPK II, Dynatech Supermaxx SS LT headers & SS cats, Flowmaster American Thunder cat back, Magnecor wires, Flex-a-lite 282 monster fans, B&M Hi-Tek trans cooler . No DEathCOOL.
    And an ls1.com decal on the back window&#33;
    <div class='quotetop'>QUOTE(DogsnHawgs &#064; Dec 22 2006, 10&#58;16 PM) [snapback]77149[/snapback]</div>
    Actually I did get a second opinion and I looked under there myself. It seems that if I put the pan on, then the Y pipe will be touching it. The second guy said I would loose all of the cooling benifits of having the fins and bigger pan if the pan is touching t the exhaust.
    Made sense to me. Maybe when I get my LTs and ORY pipe it will fit better.
    Yeah, if it was even close to the pan it would heat up the fluid. I think Bud8Fan had one to install also and he ran into the same issue. Makes me wonder why GM would cross the exhaust under the pan in the first place. In the OBS trucks they ran the crossover under the bellhousing.
    Jun 2005
    Do you have the stock exhaust?
    I ask this because both my stock exhaust and my Dynomaxx LTs both crossed in the space between the crossmember and the transmission pan on the 4L60E.
    Since the 80E I installed is longer, the exhaust crossover is about in the center of the pan. I am also running the Hughes deep pan on this transmission and I still don&#39;t have any problems with clearance.
    I will take some pics and post them if you like, just let me know.
    Jun 2004
    george west texas
    yep red is right..i had the same issue with the deep pan as well...would not fit because of the cross over exhaust pipe being to close to the stock pan...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
