Thread: Corvette filter question.
    Feb 2004
    Is there an adapter that will go in the female quick connect fitting, and leave me with a threaded fitting on the other end? I need something that I can adapt to an AN fitting for the rest of my fuel system.
    Couldn't find anything in search, and the PN's I did find don't say what each adapter is.
    '91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, '00 LS1 and 4l60e. Almost all done!
    http://s57.photobucket.com/albums/g220/98hd/Chev/
    San Marcos Texas
    I used a repair kit from autozone that is steel line, double flaired it and adapted it to NPT. Then you could adapt NPT to AN.
    An adpater with a 3/8" compression fitting to -AN will do the trick after you buy a 3/8" quick connector to plug into the filter.
    Feb 2004
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Aug 29 2006, 05&#58;45 PM) [snapback]62940[/snapback]</div>
    I saw your post in the part numbers thread, and finally joiund what the last dormans piece was. If I can&#39;t finde something by tomorrow (been searching all day) I&#39;m going to use that piece w/ a compression fitting.
    &#39;91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, &#39;00 LS1 and 4l60e. Almost all done&#33;
