Results 1 to 9 of 9
Thread: First Dyno Run
    Made my first dyno run today (266hp / 296 tq) with the following mods:
    ECSB w/5.3
    K & N FIPK
    Edelbrock Shorties
    JBA 8mm wires
    Magnaflow cat-back
    Nelson 91 Hot Tune
    cam (Comp 212/218 558/563 115lsa) springs (918's) and rods comming soon...
    May 2006
    Waco TX
    Hmmm..... I don't know if thats good or not with all the mods you have.
    Apr 2005
    springfield MO
    after re-reading this it looks like he has not installed the cam yet.
    is this 2wd or 4wd?
    Dave
    1968 Chevy SWB Fleet. 2002 5.3 all stock (for now ) Nelson Tune 4l60e w/TB converter.
    ok not stock anymore...13.3 at 101
    Now with front mount turbo... new times soon
    <div class='quotetop'>QUOTE(custom 68 &#064; Jul 26 2006, 06&#58;05 AM) [snapback]59064[/snapback]</div>
    is this 2wd or 4wd?
    Dave
    No Cam yet. I&#39;ll be installing it in a few weeks. It is 2wd with 20&#39;s
    I think the numbers look kind of low but I&#39;m not sure.
    It&#39;s really hard to judge the numbers. You could make 260HP on that dyno and go across the street the same day and read 300HP. It&#39;s all subjective. Good numbers no matter what since my LS1 only dyno&#39;d about 243. The dyno is a good tool to see what gains you make when making changes. It&#39;s best to go to the same dyno every time.
    Apr 2005
    springfield MO
    well the 20s are not helping but it should be a good base to start from. Like Red said it will let you know your gains. I need to do mine also.
    Thanks for your input guys.
    Jul 2006
    College Station, TX
    you say ECSB w/5.3 what does that stand for?
    2004 EXC Silverado 6.2L
    Mods:
    Extended Cab Short Bed
