Results 1 to 10 of 10
Thread: ANYONE KNOW?
    DBYRD Guest
    Does anyone have an idea how to convert my 99 RCSB 4.3 fuel lines to an LQ4? they don't fit right, and I've already had someone say to get some high pressure rubber hoses and triple clamp them and it should be fine, but i thought I'd ask the experts. any info would be great Thanks!!!
    Apr 2006
    Bellevue, Nebraska
    Maybe replace them with steel braided lines, or stock lines out of a RCSB with the 4.8 or 5.3?
    Stock lines would be best if available. I've done the fuel injection hose on two trucks without issue. Braided would be better. Get aeroquip or russell ends and you can bolt it all together. NAPA carries some hose connections.
    DBYRD Guest
    ok i guess they'd bolt up to the fuel pump and run all the way up to the engine then huh? any idea how much they cost?
    May 2006
    Waco TX
    <div class='quotetop'>QUOTE(Allstar55566 &#064; Jun 13 2006, 01&#58;58 PM) [snapback]55362[/snapback]</div>
    ok i guess they&#39;d bolt up to the fuel pump and run all the way up to the engine then huh? any idea how much they cost?
    The Fuel pump is connected to the gas tank. Your best bet would be to hook it up to the fuel filter under the driver side on the frame rail, assuming they are quick disconnect lines or bolt together.
    DBYRD Guest
    Angry
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Jun 13 2006, 04&#58;22 PM) [snapback]55379[/snapback]</div>
    no shit? why the hell u gotta be a smart ass? i swear ur nuts haha. douchebag&#33;
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 13 2006, 02&#58;07 PM) [snapback]55364[/snapback]</div>
    I&#39;d just call a salvage yard and see how much they&#39;ll let you pull them for. Maybe Austin, HWYAUTO, can get you a set.
    good idea ill write him and see.
    May 2006
    Waco TX
    :flipoff: <div class='quotetop'>QUOTE(Allstar55566 &#064; Jun 13 2006, 01&#58;58 PM) [snapback]55362[/snapback]</div>
    Well you said fuel pump see&#33;&#33; right there :flipoff: lol
    DBYRD Guest
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Jun 13 2006, 06&#58;45 PM) [snapback]55393[/snapback]</div>
    :flipoff:
    my bad damn i&#39;m no genius haha fudgepacker
    if you keep it all GM than there is very little chance of a failure, thats good piece of mind when putting your kids in some hybrid. (like all my trucks )the stock fuel lines are great, i have never seen a warranty
    failure yet. used low mile hose works great...
