Thread: New Times
    Jan 2006
    Well I went out to WRP today and made some passes. I improved a little over my previous times but not as much as I would have liked. I tried something different, I did a big smokey burnout and immediately staged the truck, instead of doing a dryhop or two before staging. I also dropped my tire pressure down to 18psi from the previous 20psi. The truck hooked up pretty good but I was afraid to stall it up past 1200 rpm for fear losing traction ( we only got 2 time trials & I wanted to make the best of them). BTW I went out in the 2nd round with a red light. This was my best timeslip.
    60 FT ---- 1.9028
    330 FT ---- 5.6034
    1/8 ET ---- 8.6327
    1/8 MPH --- 80.07
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Nice times there. You've got me beat by a full second without the spray. I guess I need to try some true duals and headers to catch you. You're getting some great numbers with a 98 engine.
    Jan 2006
    San Antonio
    Sweet run man. Been a while since I been up there.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Jan 2005
    Humble/Houston TX
    great time
    old mod list: H/C/I/N/E/G 408
    Jan 2006
    Thanks alot guys. Something I forgot to mention is my mph dropped off a bit and I couldn't figure out why at first but then on my last pass I realized it was shifting into 3rd as I was going through the traps. My tranny is stock and shifts pretty lazy from 2-3 so I think this is the reason for the lost mph. I figure if I raised my shift point by a hundred rpm it would solve the problem.
    Jan 2006
