Thread: update on the 86
    All the mounts worked out jut right. My factory driveshaft is perfect with the new motor mount positions. Minor fabrications to the trans crossmember and it will be done. Now its time to cut/box/weld/grind/paint/sitbackandsmile!! the frame and crossmember. All for a/c clearance. Then set her back in.
    Building a 86 Silverado 2wd sbrc, LS1 and 4L60E. Magnacharger soon to follow
    HIS: 01 GMC Sierra 1500 H.D. 4X4 crew cab, loaded, 6" RCD, 3" body, 14X36" TSL Swampers, 16.5X12 MT classic 2`s, cowl hood, hypertech
    HERS: 01 GMC Yukon, loaded, Denali front clip, 22" Giovannas, 2/4 drop, cowl hood, 2 baby seats
    Dec 2003
    That'll be sweet when it's done! I used to have an 86 back in the day. I love how there is so much room under the hoods of those older trucks for working on them.
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    Nov 2005
    ohio
    yes, ive had 3 OBS trucks and the best thing you can do to them is a GEN 3!
    Oct 2005
    Baton Rouge, LA
    So true...
