Thread: Tacky
    Apr 2005
    So the needling part of the install which has given me trouble. The tach does not work....well, its not accurate is the better description.
    I'm using the stock instrument display from my 93.
    Someone had mentioned it might be analog versus digital. Any ideas on what might be wrong and how it could be fixed....
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    You need a convertor. BakerElectronix.com makes one for about $35. Tell him I sent you and you need one setup for an LS1 and let him know if you have a 6 or 8 cylinder factory tach. Its a little bitty thing with four wires.
    Apr 2005
    Thanks man
