Results 1 to 10 of 12
Thread: 7 wires left then I can start. HELP
    Nov 2005
    All I have left to do before strating my truck is hook up these 7
    wires from the PCM. The guy who built my wiring harness is
    long gone. Please Help.
    1. Purple w/ white stripe-- It says Tranny plug
    2Yellow-- It says Tranny plug
    3.Dark green-- It says Serial Data
    4.Green w/ white stripe-- It says VSS Out 4k
    5.Yellow-- It says Serial Data
    6.Two Green wires-- It says B.U.
    7.Yellow w/ Black stripe-- It says VSS out 128K
    I don't have cruise.
    I do have a elc. speed-O that I need to hook up.
    Thanks for any help. Ive been waiting 3 weeks
    just to hook up these wires.
    SOON TO COME!!!!
    Break out the ohm meter and back trace which pin number and what color connector they go to in the PCM. What vehicle is this for? LS1? LT1? I didn't know there were two serial data lines in a LS1. One might be the MIL wire and the other would be a serial data line.
    San Marcos Texas
    #4 green with white stripe = vehicle speed sesnor 4K must mean 4000 pulses per mile, use that for the speedo.
    Nov 2005
    The harnes is out of a 2000 chevy 5.3l.
    The guy who built the harnes labled the wires coming out
    of the pcm. I guess he thought I would just now where
    to hook them up. He was working for LNJ's for about 2yrs
    doing only LT1/LS1 swaps.
    Thanks GMCwantsLS1
    Thats one out of the way.
    I do not have my PCM tune yet. So I also have to figure
    out how to hook up this VATs module he gave me.
    SOON TO COME!!!!
    3. Dark green is probably the serial data for the obdII diag plug. I believe it's Number 2 on the obdII plug. Also, 4 and 5 need ground and 16 need battery, I'll check this again to be sure, but I just got done hooking one up and that should be it (from memory).
    Like it was said, trace them back to the pcm connector and identify the pin #, then we'll know for sure!
    btw, give me a call, forget the vats bypass,
    allen
    San Marcos Texas
    I can't seem to match those colors with my wiring schematics. You will probally need to ohm out the wires to the pcm pin locations and then we could be more help. Sorry kinda slow on the responce looks like the other two gave a similer responce
    Nov 2005
    Thanks Guys
    Ill trace them back to the PCM and post more.
    Maybe Ill be abel to here this thing run after all.
    SOON TO COME!!!!
    Hopefully your's sounds better than mine. Right now mine sounds like a top fuel dragster! Oh well, at least it runs and drives.
    Nov 2005
    Here we go, I got the #s and found one more wire.
    Goes away from PCM
    Goes away fromPCM
    #58 BLUE on PCM
    #50 Red on PCM
    #59 blue
    Goes away from PCM
    #49 red8. Green ---it says S.
    away from PCM
    9.Gray--- It says S.V.
    #48 Blue on PCM
    10. 2 black/ black and white wires
    SOON TO COME!!!!
    VSS out to speedo
    Purple and Yellow to speed pickup on tailshaft
    black/black and white to ground
    Dark green to serial data connector on OBDII connector, not OBDI
    gray might be fuel pump relay ground
    I am just guessing, trying to remember. Will confirm later. LUNCH TIME!!
