Results 1 to 8 of 8
Thread: suspension
    i was looking through some suspension kits and im pretty sure im gonna go with bell tech. but the actual belltech site only showed a 2 inch in front and 3 inch in back. im looking for a kit that has 2 in the front and 4 in the back like ross's. but i havent had any luck finding them. any help would work. thanks
    david
    try www.mcgaughys.com and see if they have what you desire. Their's is very well engineered.
    yeah they have it right their on the page you put. but it doesnt have a price or anything such as that. oh nevermind i guess you call and order it. its at the very top of the "drop kits" is that all i would need for my single cab truck? wouldnt i need a set of spindles too?
    They have numerous ways of achieving your desired level of drop. I'd sure call them and ask their opinion. Their drop spindles are second to none.
    I hear that other brands have problems with bump steer and McGaughy's doesn't.
    really? thanks for the advice. anyone other suggestions would help. thanks
    Sep 2004
    Spend a little extra and get the McGaughy spindle and keep the stock springs. You won't be sorry! DO NOT BUY BELL TECH SPINDLES!!!!! They are horrible. You will end up with twitchy steering and severe bump steer issues.
    If you can't afford the McGaughy spindle just put a 2" spring in the front. Just the springs aren't as good, but they aren't bad either.
    Good Luck!
    It will look really good with the drop kit on it.
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    alright so mcgaughy spindles, no springs and the rest of the mcgaughy kit? that comes for the 2/4 drop?
    Jul 2005
    modesto, ca
    Hotchkis has an awsome 2-4 kit. You can get it with or with out sway bars. If you take it to a local shop and purchase there kit, beware some shops put on dearched stock spings.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
