Results 1 to 9 of 9
Thread: Who belives in ASP pulleys
    Aug 2005
    Spring, Texas
    I recently have been buyin' stuff that i would not normally buy for the truck. And one thing that has cross through the ole noggin are those controversial (problaby didn't spell that right) ASP underdrive pulleys, i have noticed not many guys here have them and there has to be a reason behind that. I don't mind the $200 if it is a good product. If it only is 5-10hp who cares it is 5-10 hp that i didn't have before. I know money can be spent wisely somewhere else, but I am already in the process of the whole cam, stall, rods, springs, retainers, shifkit thing. And i wouldn't mind a little horsepower now.
    How do you guys feel about this product?
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Its your money, buy whatever you like.
    Most people don't buy them due to false knock often associated with an aftermarket pullies or dampners. Underdrive pullies alone will cause your alternator to turn a lot slower and kills the efficiency of your alternator output and water flow rate. I guess if you're running a higher gear ratio in the rear end you're going to be turning enough RPM to offset the smaller pullies.
    Honestly, the thought to add them has crossed my mind numerous times lately. Then again, I have been in the "throwing money down a hole" mode for a while now.
    Aug 2005
    Spring, Texas
    Good point, but you can get a smaller alternator pulley to offset the slowing efficiency rates.
    And Also Just purchased 145A alternator today.
    I say go for it but do a before and after time trial to see what you gain.
    Aug 2005
    Spring, Texas
    Before and After would be a great Idea.
    I want to hear from someone who has these pulleys and see if they like em' before i buy them. You know what I mean?
    Aug 2005
    houston TX
    i have one on my truck its alright i picked up 7hp and 10tq i can feel alittle difference and it revs alittle faster and u lose a little weight my stock one was 12 lbs and the asp is 9 but it does slow down the water pump and fan and if i dont watch it it will get hot if i am just sitting there in 110 dregree heat now that its cooled down out i dont have a problem. i need electric fans
    03 1500HD 4x4 6.0 on 33"
    K&N intake, Pacesetter LT, 3" true dule orp, Magnaflow, Comp cam 237 242 .603 .609 112, Patriot Gold springs and Ti retainers, stock ported heads, ASP Underdrive pulley, 42# injectors, 160 tstat., 05 E-Fans, Nelson Fan Harnas, tb bybass, MSD wires, NGK tr55, Ported tb, Transgo HD2, yank 3200 conveter, HP tuners, Walbro 255, 4.56s
    Nov 2004
    I gained the same as bigpat502, 7 RWHP AND 10 RWTQ, Allen did a before and after dyno, when we put mine on. I think that they are worth it in my opinion.
    01 CHEVY 2500HD 4X4 ECSB, K&N, Pacesetter LT'S, 4.10 GEARS, 4L80E, 285/75/16 NITTO TERRA GRAPPLER AT'S , ALPINE CD PLAYER, 2 MTX 10'' SUBS CUSTOM ENCLOSURE, MTX 800 WATT AMP. NELSON TUNE, ASP PULLEYS, AND 05 E-FANS, Flo-Pro HD MUFFLER, LS6 PCV CONVERSION.
    Mar 2005
    should you go under or over drive alt pulley with the underdrive crank which is better
    2000 RCSB SS 2WD 6.0L LQ9 4L60E
    LS6 INTAKE, MSD WIRE, 80MM BBK THROTTLE, AIR AID THROTTLE BODY SPACER, BODY, 80MM SLP AIR METER, 36LBS INJECTORS, LS1 ELECTRIC FANS, YANK 3200 STALL, 4.10 GEAR, FAST FUEL RAILS, COMP CAM .224 .230 .581 .592 114LSA WITH 918 SPRINGS, PACESETTER LT HEADERS, 3" EXHAUST DUAL SUPER 40 FLOWMASTERS AND CUTOUTS, NELSON TUNE, SLP 160 THERMOSTAT, THROTTLE BODY BYPASS AND NO EGR OR CATALYTIC CONVERTERS.
    4L60E WITH STAGE 2 SHIFT KIT AND VETTER SERVO
    FUTURE MODS: STAGE 2 HEADS, SUPERCHARGER, UNDERDRIVE PULLEYS AND A 6 SPEED TRANS
    Oct 2003
    TeXas
    you wont need the oversized alt. pulley it will just make it harder to keep the amps up, if anything you want a smaller pulley for the alt.
    http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
    RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
    04 GTO
    Both Tuned By: ME
