Results 1 to 10 of 13
Thread: Stupid spark plug leads!
    Mar 2004
    Springfield
    So I am changing out my spark plugs and pull a lead. Well my buddy is helping me and I told him not to pull any other leads, that i had to do them one at a time. Well what does he do? He pulls one and mixes it up with the one I just pulled. Now I don't know which one went where. So I just got frustrated and left it so I don't screw it up by putting the wrong lead in the wrong cyclinder.
    I had the stock ACDelco wires and was hoping someone could tell me which wires went where.
    You know, like a spark plug map?
    A firing order?
    An old diagram you drew up?
    Something.
    It's a 2000 Chevy Silverado 4.8l.
    If ANYONE that still has the same stock plugs in their 99 or 00(which i doubt) can you please tell me the order the numbers are in. There is a little number on the side of the boot which connects into the coil, if you could tell which order they are in I could use it.
    Left Side<---&#62;Right side
    1._________ 5._________
    2._________ 6._________
    3._________ 7._________
    4._________ 8._________
    Thanks,
    Kinjo
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY&#39;S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    DRIVER SIDE radiator end of engine is number 1 then 3 then 5 then 7.
    PASSENGER SIDE radiator end of engine is 2 then 4 then 6 then 8.
    Your 4.8L isn&#39;t one coil per spark plug? It won&#39;t matter if that is so, the cables are too short to mess them up.
    If it still has a distributor, the firing order will be embossed on the intake manifold. Typically GM timing on a distributor type engine is 1-8-4-3-6-5-7-2 unless you have a newer replacement cam that flips the firing order of two cylinders that is supposed to smooth the power curve of the engine out.
    Now, you are talking about a 2000 GM 4.8L engine?
    Aug 2004
    Ok, if this is on a 00 4.8 then I am really lost. What do you need a wire diagram for? You have 4 coils on each valve cover, directly below each coil is a spark plug. The wires just run straight down to the plugs from the coil? Did I miss something........
    Now if this is on a old school chevy v8 with a distributor then refer to the previous post.
    04 Sierra Denali
    Blown,Cam'd,stall'd etc.
    Dec 2003
    Azle,TX
    I didnt want to sound like a smart ass but my wifes 4.8 is one coil per cylinder like my 5.3.Does the 4.3 V-6 have a distributor or single coil?
    Vortec Performance Tuned
    Oct 2003
    Houston
    The 4.3 V-6 has a distributor with one external coil.
    99 Pewter SCSB
    DJM 4/6 drop, Hotchkis front/reat swaybars,Hypertech power programer, milled & built heads, Accel wires, distributer,coil, Mass Air Flow Sensor(mti motor sports, Granatelli),Dynomax UltraFlow Stainless, 17x8.5 Eagle Alloys, Escalade door handles, Suburban front grille, with clear corners and billet bowtie,Street Scene mirrors, Cowl Hood
    Aug 2004
    Yes the 4.3 has a distributor and one coil, however I was under the impression that he was refering to the 4.8L ?
    04 Sierra Denali
    Jun 2005
    Cumming, GA
    Originally posted by kinjo1977@Oct 15 2005, 01:15 AM
    It&#39;s a 2000 Chevy Silverado 4.8l.
    Yeah, ya got me on that one. But, he was referring to the wires as "leads," which (and I&#39;m not tring to be an ass here) is not typical of someone in the U.S. So, maybe he is in another country and his truck&#39;s 4.8 does have a distributor
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    Dec 2003
    Azle,TX
    I think hes talking about the leads to the coils I am an ass
    Dec 2003
    Azle,TX
    Hey kinjo....Are we gettin warm yet
    Mar 2004
    Springfield
    Everything is taken care of fella&#39;s.
    Thanks for all the input.
    Honest to goodness truth, this was the first time I have changed those stinking things out. Freaked out cuz I didn&#39;t realize at the time I wrote this that all the wires are the same length because they all have seperate coils. Thus it didn&#39;t matter if I mixed them up or not.
    The next morning after I wrote this I smacked myself after realizing my ignorance and changed all the plugs and wires in about 45min to an hour.
    Pretty good for first try huh and with NO help. I decided that my buddy was more help than good.
    Anyways, I used ACDelco wires and ACDelco Iridium plugs. Can&#39;t go wrong with that combo
    Only cost me a whopping &#036;153 bucks.........stupid delco wires&#33;&#33;&#33;
    Of course those plugs were &#036;6.58 a piece also&#33;&#33;
    But she is running strong now. Started right up with no hesitation.
    Thanks,
    Kinjo
    P.S. I said "leads" because that is what was printed on the instructions and that is what the parts guy called them. I am just a redneck from TN.
