Results 1 to 2 of 2
Thread: posi
    Apr 2005
    how easy is it to install a posi rearend like an eaton do you just bolt it in or do you hafto worry about backlash and shit??? or is that just when you change gears???
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    You still have to mess with backlash but that is the easy part. Since you aren&#39;t changing the pinion gear out you don&#39;t have to worry about pinion depth. That makes changing out the diff a lot easier. Feel the amount of backlash you currently have and try to match it or tighten it up just a smidge. Backlash is set by moving shims from one side of the diff to the other. Shim kits are available at most auto part stores or you can order them online from Randy&#39;s ring and Pinion or CaliforniaGear.com.
