Results 1 to 5 of 5
Thread: ok now what?
    Mar 2005
    Eagle Pass
    I just picked up a low mileage 5.3 today,(thanks Again 00GMCSLT ) I would like to build a 750 hp Streetable(i use that term reeealy loosely) engine in my 2000 Silverado. What Do i need To Do To Get Some Serious Power outa this thing, can someone point me in the right direction to get a few more cubes outa this little ol 5.3, What pistons Do y'all Reccomend., This Will Be A Boost Freindly engine. I plan on Purchasing a Upgraded STS Turbo Setup with intercooler , people tell me 750 hp is unrealistic , was going to buy a Bone stock 6.0 from the GM dealer, and boost it till the pistons cave in to try to get to 750 hp, But I figure $3,400 going into a 5.3 Block could go further, am I wrong?
    Dec 2003
    Azle,TX
    Glad to see you made it back to OK How about twin turbos and a cam Your biggest challenge is getting that black beast to hook up
    Vortec Performance Tuned
    Mar 2005
    Eagle Pass
    I am currently lookin @ a 5.3L to 6.3L Stroker Kit, found one for $2,200. Would punchin out the engine that much make the engine too Weak to run 12 psi of boost? should I leave The engine displacement @ 5.3 but get good rods,crank and pistons, and just turn up the Boost to get the power I want... I kinda want about 500-550 for everyday drivin , and want to kick it up to like 750 to Smoke a Ford lightning :flipoff: if that Oppertunity ever presented itself.. I figure I'd need about 750 to do that cause my damned extended cab truck is kinda heavy!
    any advice would be appreciated
    STS system with T76 and running about 8.0-8.5 compression and close to 20 lbs of boost when racing.
    Jul 2005
    modesto, ca
    You can safely bore a 5.3 block out to 5.7 then stroke away as much as you want.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
