Results 1 to 7 of 7
Thread: help me kill the door buzzer!
    Sep 2003
    2004
    May 2004
    can prolly pull the switch in the door jamb and soldier that closed at the wires or just twist them. Otherwise you will have to track down the actual buzzer and it is prolly behind the cluster and dis-connect it.
    Good Luck
    Feb 2004
    Western, KY
    the door dinger is located inside the Body Control Module (BCM). Pull the wihte brown and purple connector out out of the BCM and remove the plastic shell via a screwdriver or you fingers if they are small enough. After you remove the shell you will see a black cylndrycl object (the dinger) and either unsoldier or shove some paper in the small opening in the annoying piece of shit and problem sloved.
    Mods:
    Maybe STOCK
    "My lugnuts require more torque than your ricer is ever going to produce"
    Sleep: That Stuff Is Overrated
    "You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
    Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
    Austin, TX
    nope if it is a 2004 it is through the radio and the dinging come's from the speaker in the driver door I haven not hear of a fix for this yet
    Red 94 GMC Sonoma
    Red 94 Jeep Wrangler
    Red 02 RCSB Silverado
    Red 03 Ford Cobra
    Red 04 CC Silverado
    Red 05 Yamaha Raptor
    I really like red
    Nov 2004
    Victoria,Texas
    there is a reflash to lower the volume of the door chime
    01 1/2 ton suburban, 6.0L, MTI stelth 2 cam, MTI 2.055/1.60 heads, GMS Maf, 3200 yank, Dynatech headers, King cobra air intake, 42# marine injectors, 05 electric fans, ls1 edit, fourth set of 4.56 gears. Fast for a led sled.
    Damn, wish I had that problem.
    Mar 2004
    Springfield
    See what ya do is, take a big a$$ hammer and smash the hell out of anything that dings. Problem solved.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
