Thread: Will this work on my 02 silverado 5.3
    Aug 2005
    Spring, Texas
    it seems that the TB will fit my truck but will the intake bolt up and help or hurt the Horsepower?
    here is the ebay site:
    Intake Link
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Jan 2005
    Conway, AR
    it'll bolt right up as far as I know!
    Chris
    Jul 2005
    modesto, ca
    It will bolt right up but I read that the engine driven fan will hit the air intake tube, so you will need to install efans.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Aug 2005
    Spring, Texas
    i was told that the intake was taller and you would have to get new belts. Also you will lose Torque?
    Feb 2005
    actually the intake is shorter than the stock truck intake, so you will have to use the accessory brackets, and water pump of an LS1 to clear the throttle body. You may lose a little low end but you gain high end. Those intakes flow more in the upper rpms.
    New Truck on it's way: '07 Classic GMC 2500HD DuraMax LBZ
    03' Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99' Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02' PCM, LT1 fans
    If you use the LS1 accessories, you have to use the LS1 crank pulley, too. Different offset.
