Results 1 to 10 of 11
Thread: obs ls swap electrical
    New guy here. Been doing tons of research and have decided to swap a 6.0/4l80e combo into my 1997 gmc 1500 4x4. Its got the factory 350/4l60e right now. I've got some questions though.
    I plan to keep my original ecm to continue to run everything but the engine and trans. Keep gauges lights signals cruise etc. Running off old ecm. Then I want to use the donor trucks ecm for solely running the engine. I'm maybe a bit comfused as far as wiring goes. Is this what a stand alone harness is for?
    I will be taking everything from the donor including wiring harness, ecm, exhaust manifolds, tranny, and possibly torque convertor. Everything attatched to the engine basically.
    How should I go about this? By splicing the data wires the nbs ecm needs to run the engine from the old ecm? Or this is where say Nelsons stand alone harness comes in?
    I also think I'm going to find a 2002 as it should have the aluminum heads but still be dbc. Is there anything I need to do when converting to the 4l80e other than move my crossmember a bit?
    To make things simpler I'm following a write up on S&P's website where they swap an 03 (I believe) 6.0 into a 97 ukie. For ease of install I see myself using mostly S&P adapters etc. will See how it goes. I do have a few questions about the harness they have. Does it marry the old 97 harness to the nbs 6.0 harness?
    It seems to me if I used the adapters from s and p, where would the 6.0 ecm get its info (engine temp cam position oil press etc) from? I think I'm just confusing myself now.
    Sep 2012
    Quakertown, Pa.
    I may be able to answer some questions. Here goes;
    You will need the new PCM to run the engine/trans combo. When getting the harness, get everything. It makes it easier when you have the complete harness. Even the harnesses going to the O2 sensors.
    When it comes to using the old PCM, it's usage will be limited. Your guages will operate from the original senders mounted on the new engine. Your tachometer will get input from the new PCM as well as the speedometer. I believe the cruise also needs to be hooked into the new PCM. I think the only thing the old PCM will run would be the anti lock brakes.
    As for running the 4L80E, you will need to move the crossmember back to accomodate the transmission's longer length. Since this is the case, the rear driveshaft will need to be shortened and the front lengthened as well.Unless, of course, you have the donor vehicle driveshafts and the wheel base of the donor is the same length as your truck.
    S&P will be a big help with all the adapters and engine mounts they have. Stand alone harnesses usually need a source of keyed power, a ground and constant power. Not sure if they splice into your original harness with the exception of what's needed to run the engine.
    Quite a few guys here have done this swap with this year truck. Hopefully, someone will chime in and correct/add to what I've said above. My swap was a little different as my truck is older and uses a '99 6.0 engine.
    John
    May 2007
    Oak Forest, Illinois
    You do not need to run two PCMs on a 96 and up truck if you are using a Gen3 engine with the LS1b PCM. The PCM with the 2-80 pin connectors. The LS1b PCM will run EVERYTHING on your truck just like it came from the factory.
    Jeff
    Edmonton, AB, Canada
    For the oil pressure sender alot of people say you have to use the obs one with an adapter. I used the ls oil pressure sender as it was only one wire. My 5.3 was a 99 though.
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
    Jul 2013
    Eastern Oklahoma
    Jeff, are you bypassing the anti-lock brakes or are you able to run them on the new harness and computer ?
    May 2007
    Nothing gets bypassed.
    Long Beach California
    Quote Originally Posted by Lextech View Post
    just to clarify, jeff, you stated a few comments ago that everything can be run off of the ls pcm if you have a 96+ truck. But if its earlier (88-95) as mine is the 95 (which is worse since its a transition year) what CAN'T be run??? i kept my pcm to run the ABS since mine wasnt the black pcm. other than abs, i use the new pcm for everything else. anything im missing?
    EDIT: i also use stock DRAC box to control speedo but i later found out that i can use ls pcm to controll that too. that was my bad.
    May 2019
    I'm doing a 5.3 swap in a 98 gmc sierra 4x4 using original trans whats easiest way to put the the two harnesses to gather
