Nothing gets bypassed.
just to clarify, jeff, you stated a few comments ago that everything can be run off of the ls pcm if you have a 96+ truck. But if its earlier (88-95) as mine is the 95 (which is worse since its a transition year) what CAN'T be run??? i kept my pcm to run the ABS since mine wasnt the black pcm. other than abs, i use the new pcm for everything else. anything im missing?
EDIT: i also use stock DRAC box to control speedo but i later found out that i can use ls pcm to controll that too. that was my bad.
CALI LEGAL ENGINE SWAP!
kewljay,
I have never done an 88-95 truck. I have no experience with them. On the 96-2000 GMT400 body trucks it is a seamless upgrade. Every truck function that worked before the swap will work after the swap if it is wired and tuned properly.
Jeff
