Results 1 to 8 of 8
Thread: Comp Cams 26918-16 Vale Springs
    Mar 2011
    Gibbstown, NJ
    Exclamation Comp Cams 26918-16 Vale Springs
    I will be selling them for $205 shipped anywhere in the USA, these units are new in the box never opened. I will be taking orders on them on demand. Soon I will be doing the Comp Hardened Pushrods as well. PM me for more info.
    Specs are as follows.
    COMP CAMS PART NUMBER #26918-16
    BRAND NEW IN THE BOX COMP CAMS BEEHIVE VALVE SPRINGS FOR GM LS GEN III-IV ENGINES UP TO .625 LIFT.
    COMP® Cams GM LS Beehive Valve Springs
    With a .625" maximum lift, these Beehive™ Valve Springs were designed for hydraulic roller cams in LS1, LS2 and LS6 engines. COMP Cams® Beehive™ Valve Springs deliver increased valve train stability and a much lighter valve train. This is achieved with less spring pressure for better valve control and reduced weight of both the spring and retainer. The unique Beehive™ shape handles valve train stress more efficiently to eliminate damaging harmonics and increases high RPM horsepower and durability. The oval/multi-arc wire shape places the maximum area of the wire at the point of highest stress to handle valve train stress more efficiently and allow better heat dissipation for longer life. Because of the unique Beehive™ design, the valve train can handle more RPM and more aggressive cam profiles.
    VALVE SPRING SPECIFICATIONS:
    Part# O.D. I.D. Seat Load Open Load Coil Bind
    26918 1.075 .650 125 @ 1.800 367 @ 1.150 1.100
    Rate
    (Lbs./In.) Titanium Retainer Steel Retainer I.D./O.D. Shims
    Locator
    372 772-16 774-16/1772-16 4705 4753
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
    Mar 2011
    Gibbstown, NJ
    BLACK FRIDAY SALE !!!!! Read first post
    Mar 2011
    Gibbstown, NJ
    black friday sale over!!!
    Feb 2011
    Barnwell, SC
    Can I use stock hardware with these? And how long will you have them for this price?
    99 Silverado 4.8l : Soon to be 80E swapped, then 6.0 swapped, ......
    05 Yukon Denali 6.0l : Nelson Performance Tune, ......
    8X S10 Blazer on a 8X 3/4 ton frame : 5.3l swapped, Nelson Performance tune, Schoenfeld LT's, 226/226 .598/.598 112, TH350, planetary doubler, NP 205, locker, spool, 38's, ......
    Quote Originally Posted by blacksss46 View Post
    couldn't agree more. its like boobs you'll get a C and end up wanting a D...just get the bigger one and be happy
    Mar 2011
    Gibbstown, NJ
    PM Sent
    Mar 2011
    Gibbstown, NJ
    bump
    Mar 2011
    Gibbstown, NJ
    Ttt
