Results 1 to 7 of 7
Thread: Rear brakes reworked, now clicking?
    Jun 2005
    Howdy,
    I recently put all new brakes on the rear of my truck as the front brakes were still fine. I replaced pads, rotors, and parking brake shoes. Now theres a problem, it clicks. Whenever i hit the brakes from say 45-0 it clicks/clunks and its starting to annoy the hell out of me. I was sure it was the drivers side rotor not being a truly level surface. Napa gave me another rotor for free and it turns out its not even on the drivers side, its on the passenger side. Should i swap the rotors and see if the noise is coming from the drivers side and if it is then ask them to re-surface it or replace it again?
    Truck is a 99 RCSB 1/2ton 2wd.
    Thanks in advance,
    Dave
    Apr 2003
    Mansfield, Texas, USA
    Don't ya love that rear disc setup GM made?
    Jun 2005
    Does that mean that you have the exact same problem as i do? Only thing i can think of after applying a hefty amount of syli-glide was that the rotor(S) might be slightly warped enough for them to make a clicking noise.
    Dave
    Apr 2003
    Well...
    My '99s didn't work and had to find a friendly inspection place. This was constant.
    The '01s failed and let the truck roll and nearly killed me while I was under it. I have slightly warped rear rotors on the '01 and the inner right rear pad died on its own.
    Pretty lame to me.
    What would happen if you installed a line-loc on the rears for a parking brake? Would it hold up? It should work good enough to pass inspection, shouldn't it?
    Apr 2003
    I don't see why not, just seems like a lot more work than need be. I shouldn't have to fix GMs mistakes in my brakes.
    I hear you there. I wonder if they have a service bulletin on the e-brakes. That is definitely something the national highway traffic safety commission would make them fix since it's a safety issue and seems to be a common problem.
