Results 1 to 5 of 5
Thread: where to connect the fuel pump control wire
    Feb 2012
    are you guys running the new wire all the way to the pump or using the existing,
    can i just connect it to the fuel pump 12v wire at the stock relay box, 99 obs
    I am buying the racetronix hot wire kits that bring a heavy gauge wire all the way to the fuel pump connector at the back of the truck.
    Feb 2012
    will you be using the stock fuel pump, my new harness has the relay for the fuel pump already I will like to know if i should run a new wire to the pump or just connect it by the stock relay .
    Sep 2011
    I clipped mine at the relay, either way will be fine
    Jan 2012
    warwick ny
    I used my old wire.My new wire harness has a fuel pump relay so i connected the fuel pump wire right under the hood 1992 pickup so the factory fuel pump fuse is still being used.
