Results 1 to 10 of 34
Thread: ls3 4l80e swap , about to begin
    Feb 2012
    finally im about to start my swap i have all parts ready minus fuel filter and lines.
    motor just came in today.
    i also recently found out that my e67 its not compatible to work with a 4l80e .although the truck came factory with this trany .
    I have a question for yall can i make my stock ecm controll the tranny and just use my gmpp ecm to control the motor?
    I want to avoid having to buy a new ecm harness and trans controller. any info will be apreciated.
    Hmmmmm.... 80e not compatible?
    Feb 2012
    thats what the tuner said that is not compatible with any OS from an e67.
    Jan 2012
    I have put the 4L80E on several E67 computers and not had any issue.
    It has more to do with the programming in the Trans computer then the Engine computer.
    If you don't mind telling, how much did the ls3 run you?
    I think your tuner doesnt know his ass from a hole in the ground. Just my opinion of course.
    Wow that motor looks NASTY!!!!
    I was just looking at that in the GMPP catalog, good luck with your swap I am sure it will fly!!!
    Feb 2012
    the motor was 6k with shipment,
    im going to change rod bolts in it. it also comes with ls9 head gaskets ill probably put a tvs2300 in about a year.
    I have gmpp e67 with stand alone harness this will make the engine run, can i make this work with my stock ecm and tranny, and not have to buy a trasmission controller...
    Feb 2012
    i bought an engine stand last week and got the engine fully assembled , im working on a coil relocation bracket its just that this truck coil are to big.
    also foud out that i can run a trailblazer ss 2007 OS ,ecm / t42 to make my setup work now I need a way to get a t42 harness and tied into my gmpp harness.
    I will call nelson performance to see if they can do that for me.
    any Gen3 starter should work.
