Thread: 14 bolt 9.5 carrier
    14 bolt 9.5 carrier
    Looking for a good carrier unit so I can get the OBS back on the road. Let me know what you have available. BTW, this is the unit that has the C-clip axle and axles flanges bolt the wheel onto it rather than the full floating axle that has splines on both ends.
    Houston
    I just sold my 14 bolt but i have a set of new 4.10 motive gears, and a rebuilt kit that's missing a few shims and seals but the bearings are there with gasket and all the pinion shims. Just in case you find a carrier without all this and need it.
    I will keep that in mind. I have a set of factory 4.10s out of a low mileage TBSS sitting on the shelf waiting for me to find a carrier.
    Spiro, Oklahoma
    I have an open carrier in the rearend I'm using for my OBS build, I plan on swapping it out for a G80. Let me know if you're interested.
