Results 1 to 9 of 9
Thread: LS6 AC issue in truck
    Nov 2010
    Coldspring, TX.
    Since I had a v6 in the truck previously, I was planning on using all the accessories from my LS6 with my truck conversion. However, I've discovered that on the '02 truck (harness I'm using) the compressor has a high pressure switch built in the compressor (the rear connector). The ac compressor on the LS6 doesn't have a high pressure switch. Any ideas what to do here? Can I ignore the high pressure connector on the '02 harness?
    I thought about just installing a truck ac comp and bracket, but wouldn't you know it.... the pulleys do not line up and best I can tell, this method would require swapping everything to a truck accessory setup.
    Current project.
    1957 Belair
    SOLD!
    http://www.ls1truck.com/forums/my-ga...rkwhite61.html
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    Pittsburgh, PA
    i run fbody accesories and truck AC bracket and compressor. its simple if you enlongate the holes some the pulleys will line up. If you vette accesories no chance in hell to get truck bracket to work
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Nov 2010
    Coldspring, TX.
    Crap. So now I have to buy an F-body water pump, power steering pump, alternator and f-body alt/power steering bracket and scrap (sell) the vette accessories? What is the best solution here?
    Current project.
    1957 Belair
    SOLD!
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    Pittsburgh, PA
    vette accessories bring big money, sell them pocket money buy fbody ones and bam...two wins
    412 Motorsports
    Nov 2010
    Coldspring, TX.
    Do you have the f-body alt mounted in the original low position or are you running a high mount aftermarket setup? Any clearance issues if you are running the original low mount?
    Current project.
    1957 Belair
    SOLD!
    1999 Silverado RCSB
    2004 LS6
    4/6 drop
    frame off rebuild
    Pittsburgh, PA
    besides truck AC i have all fbody accesories!!! been this way since early 06...so no issues it allows for cleaner and more room
    Quote Originally Posted by rkwhite61 View Post
    412 Motorsports
    Nov 2010
    Coldspring, TX.
    Thx for all of your help Quik. Much appreciated.
