Thread: hp tuner vs pro
    May 2011
    Buffalo, NY
    hp tuner vs pro
    So looking through their site, and the tuning section here and pt but can't find the exact answer. I understand that the difference with pro is the box that can do data logging and run wb input and the ability to do sd. If I don't plan on doing sd and only running NA for the next year year or two (can upgrade later) what are the other benefits of pro? As always, thanks fellas!
    The only difference between standard and pro is the ability to log ANY stand-alone 0-5 volt sensor. You can buy standard, and then later if you want to upgrade send your cable back to HPT and they'll upgrade it. At least they used to.
    May 2011
    Buffalo, NY
    Ahh, cool. Thanks!
    You can upgrade but it's not free.
    Arizona/Utah
    The upgrade is 289$ I wish I had bought pro in the first place now.
    I've never logged AFR with mine, and I have had pro for 1.5 years
