Results 1 to 9 of 9
Thread: Whats easier -changing rod bearings while engine is still in truck --
    Oct 2011
    2000 2500 4x4 silverado with 6.0 & 180,000 miles , should i pull the engine or try to change rod bearings while still in the truck ? i hear a slight knock when i start it in the morning -it goes away after it warms up,other than that it runs strong and doesn't smoke ,leak or use oil ...........any help is appreciated
    Ponca City
    Prolly just piston slap man. Don't think that a rod bearing change is needed. And if so I would remove the engine
    Slowest in Oklahoma...
    Dec 2008
    South Carolina
    could just have a lifter that has to pump up...mine old 5.3 used to do it bad
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Yep that's definitely not a rod bearing.
    Mar 2011
    Amarillo TX
    Quote Originally Posted by chvy=power View Post
    +1 mine does the same thing, has for years
    2000 ECSB 5.3L with K&N CAI, true duals with flowmaster 40s, and 200k miles!
    Most likely not a rod and if you wanna anyway, both ways suck. I'd prolly pull it because of other issues you might find along the way. You'll have to pull the front axle to get the pan off.
    Mar 2010
    Paris, TX
    I agree that it is not a rod. However, if you ever have to do rod bearings. It is mush easier with the motor out then in the truck. I tried it and pulled the motor to make it easier.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
