Thread: drive shafts
    Feb 2010
    drive shafts
    i just did an 80 swap in a ecsb and am wondering if there are any driveshafts from other models that will fit i think a heavy half ton ccsb will fit but not sure.
    Hand p&p heads, 219-227 .607 .613, pacesetter, tbss intake, 92mm t-body, cai, e-fans, 14 bolt, 4.56, true trac, pi 2800, 33's, 4l80e built by me
    In the makin
    Boost.
    Broken Bow, OK
    A Crew cab is longer, just get one from a ECSB 2500 with the 4L80e. You might have to put in new rear u-joint to make it fit the 10-bolt rear.
    Use the 60e shaft with a new yoke for th400
    Or just have one made......
