Results 1 to 10 of 67
Thread: 1991 Silverado frame off rebuild-LS powered
    Spiro, Oklahoma
    So first off I'm horrible at keeping a build thread updated but I'll really try to finish this one.
    I had the frame, rearend, and suspension media blasted by "Just Take It Off" Media Blasting out off Muskogee Oklahoma. Their prices are reasonable and they can come to you if you can't get to them. PM me for their contact info.
    Painted with flat black epoxy primer and a satin black industrial paint from PMI.
    I'll try to get some pics up tomorrow of the engine and rearend. I think I made a good choice on the rearend, It should definitly be able to hold up to anything I can throw at it.
    Dec 2004
    San Antonio, TX Area
    This is going to be so cool. I want to do that to mine so bad.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Again, feel free to call any time and I'll make the 15 minute drive over to help.
    Wait, there's actually a Muskogee, Oklahoma? It's just not the song, cool.
    Lmao. You'll actually drive through it if you take the map I made for you coming south.
    Spiro, Oklahoma
    I wish I had thought about that a few days ago when I flipped the frame by myself, my back is still reminding me it was a bad idea. I do still have a 14bolt I need moved though lol.
    Quote Originally Posted by low91 View Post
    Justin : 918-470-6988
    Spiro, Oklahoma
    Thanks, I may give you a call next weekend and see if you want to swing over and check things out. I'm hoping to get the frame rolling by then if I can find some six lug wheels then set the engine and transmission in and weld in some notches and crossmembers.
    Ok so all I have to do is swap my spindles?
    Can I still use everything else like calipers and mounting hardware
    Spiro, Oklahoma
    Quote Originally Posted by mike205 View Post
    You'll need 92+ spindles and im sure rotors. Calipers should still work but I may be wrong, it's a rare occurance but it does happen.
