Results 1 to 10 of 18
Thread: Trick turbo kit for sale in west Ga 99 to 06 4 or 2wd GM trucks $3000.00
    Trick performance products turbo kit.
    Turbonetics turbo 76mm with .96 ar this is the ball bearing turbo.
    5lb and 7.5lb springs.
    Coated hot pipes.
    4.5" thick intercooler
    Setup for maf less system /Speed density Running to a 92mm throttle body. It can be easily be modified to a 78mm throttle body. I think a different rubber coupler is all you would need.
    You will need a few minor things.
    A fitting for the oil return and a few water hoses. You have to splice into your heater hoses. You might need the fitting for the oil output on the engine. The 2500hd trucks have an oil cooler output. You can buy that piece for the oiling of the turbo. I think it is less than $40.00 I used a lingenfelter unit that allowed me to install an oil cooler that is not going with the system.
    This kit will work for 4wd or 2wd trucks.
    My price is $3000.00 + $100 for shipping anywhere in the lower 48.
    I would be willing to meet some one some where reasonably close to me. I am 1 hour south of Atlanta. I would consider trades of a Daily driver type vehicle. Preferably one of equal value. I could be persuaded to add a little cash for the right vehicle. Thanks for looking.
    Turbo Blanket goes with the system. I think I paid a couple hundred bucks for the blanket.
    Cooler is a tad dirty. Never had any meth in it.
    Installation is really easy. Only hard part was drilling the oil pan and putting in the return. That was really not that hard either.
    4.5" thick. No the dollar does not go with it.
    The coating seems to have flaked in a few places but overall is in good shape.
    Pic of where the oil return was plumbed.
    The wrap that is on the down pipe is not in the best shape. I would rewrap it.
    Not trying to start anything or mess the post up but the second pic from the bottom, showing the log manifold has a crack on that first runner that attaches to the head flange. U can easily see where there was an exhaust leak and the actual crack.
    Get it tigg'd up before you sale it and it should be good as new. Also check the entire log manifold carefully for more cracks. I can almost guarantee u there r more.
    Oh hell. I will investigate that first thing in the morning. If it is cracked I will get it taken care of before selling it.
    Sep 2006
    Coon Rapids, MN
    i am trying to save money for a turbo kit and u have to taunt me with this
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Quote Originally Posted by 02CHEV View Post
    It can be yours.
    Sep 2006
    Coon Rapids, MN
    its called $$$$$$$ and i anit got non. not makin the money i need rite now. im hopeing i will come into some soon damn it its soooooooo temping. its like a pice of cake infront of a fat kid on a diet
    04 Grand Prix GTP
    Thanks. Manifold is in transit to Trick Performance.
    Weekend bump. Other kits are listed for more money. I will also entertain best OFFERS.
    Ttt
    Oct 2006
    Wichita Falls Tx.
    Bump, buys this is a killer kit. If you are thinking about boost. This is a very good deal.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
