Results 1 to 8 of 8
Thread: NNBS Fuse Question
    Orono, ME
    NNBS Fuse Question
    Anyone know which fuse covers steering wheel control lighting, CD player lighting, 4-wheel drive switch lighting, and dome lights? I've tried all the obvious ones (I think) and my truck is still having issues. The dome lights will only turn on when the door is open, or if I turn the dimmer to dome override then turn them on. If they're on and the key is on, when you close the door they'll dim out and shut off and won't come back on. Also, my steering wheel control lights, cd player lights, and 4 wheel drive indicator lights are out... It almost seems like a fuse, but, like it said... I've been down that route.
    2012 Honda Civic Si - DD
    is there a fuse under the drivers side kick plate? under the steering column area?
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Broken Bow, OK
    Unplug the headlight switch and see if they still act that way.
    Orono, ME
    You mean just the headlight switch on the dash?
    Yep. I assume he's thinking what I am... something along the lines of the auto headlights are causing it to bug out.
    I am assuming you have adjusted the instrument cluster dial so that the lights are turned all the way down. The dome light setting is configurable by the owner. Read your owners manual and it tells you how to change the settings.
    Orono, ME
    I'll check that out, thanks Greg.
    Still don't know what would cause my CD player lights and steering wheel control lights to completely go out though... weird.
    Orono, ME
    Nevermind guys, I figured it out... fuse #17 in the instrument panel fuse block if anyone is wondering.
