Results 1 to 7 of 7
Thread: Would a 700r4 tranny hold up with 6.0 lq9
    Mar 2011
    Dade County , Fl
    Well I have a newb ? Would a 700r4 tranny hold up with 6.0 lq9 ? If NOT What tranny you guys recommend
    built properly and not pounded on constantly it might last but I will always recommend an 80e and suggest a small diameter converter to offset the heavy internals.
    id find a better trnasmission
    hey rhb, with a 80E you mention smaller diameter converter? you talking in the size of a 9.5?
    Simple: 408 on steroids!
    single digits coming soon!
    Yeah the 9.5 is great and a 10.5 would be good too. Gotta kill out the heavy mass so it can pick up the rpm quickly.
    Dec 2010
    a stock one will have hard time living behind even a stock 6.0, unless yuo plan on driving it easy you will need to to the following to the trans;
    Beast sunshell, with wide sin gear bushing, rebestos 3-4 clutch pack, carbon 2-4 band from patc with corvette servo, bittet 4th servo, borgwarner sprag, depending one the converter you choose, and hp goals with the 6.0, you will need a mega valve and oversized reverse boost valve, high rpm pump slide spring.
    I'd say anything over 360rwhp in a truck you should think about the hardened output and input shafts....price adds up quick for a 700r4 to hold power, but it can be done.
    Also stay away from pre-87 7oor4's i think they have weaker input drums and lower volume pumps, not sure on the exact details though
    Feb 2009
    i was doing the same trans these seem fairly pricedhttp://www.bowtieoverdrives.com/catalog/catalog.php?Action=GETSUBCAT&CATID=B
    Dec 2010
    Fargo, North Dakota
    Funny, I was just telling my friend that I will need to use the 4L80E and he told me to use a 700R4 behind my LQ4 (rather than rebuild the 80E). Now I have something I can tell him.
