Results 1 to 10 of 10
Thread: Rearend Noise??
    Needville,TX
    Rearend Noise??
    Wondering if this is a normal backlash noise or not. Ebrake is on holding the wheels tight.
    I also took the DS off and did the same thing. Seems like a lot of backlash to me. And has a tight spot when I sloooowly turn it.
    http://s129.photobucket.com/albums/p...ongbars001.mp4
    89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
    Mar 2007
    Newark, Delaware
    That's serious!
    Jan 2007
    Stafford, VA
    Quote Originally Posted by Beatdown Z View Post
    That's serious!
    I couldn't agree more. That is way too much slop.
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
    Believe it or not happened to my buddy two weeks ago and he had two bearing caps off his ujoint
    My bad just read you've removed your ds
    Needville,TX
    Any ideas on what is causing that much slop???
    If I had to guess I would say the spider gears are toast but I'm sure some smartass will come along and tell me just how wrong I am.
    Oct 2006
    Wichita Falls Tx.
    Time to pull the cover off and take a look. I see what you meant by truck giving troubles.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Jun 2009
    Washington DC
    Wow that is a hell of alot of play. What symptoms made you check under the truck? Clunking when braking and when pulling away from a stop?
    Needville,TX
    The only noise that was starting to bother me, almost like a dry bearing sound. I thought it was the T56 but after I ck'd this now it has to be the rear.
    Does not clank at all but hell with the exhaust I have would be hard to hear.
