Results 1 to 10 of 22
Thread: My Dads Build.
    Oct 2007
    Bandera, TX
    My Dads Build.
    Well after 25k on the single front 76mm it finally tossed the #2 piston. So in good fashion my Dad just decided to go 402 instead of just adding pistons.... It an eagle 4340 crank, eagle 6.125 rods, wiseco pistons, 9.5:1 CR and had the heads PP while we were off. Not bad for a weekend build... I built the motor friday, put it in sat, and its off and running now, and sounds great, Im sure it will shell the 60e at the raceday.... but you never know... the truck is a 2006 Intimidator SS BTW
    single digit street truck
    for build info
    Looks good is he goin to do any power adders like the turbo again or what.
    Oct 2007
    Bandera, TX
    ya, its still got the 76mm single on it. Probably going to go with a 90+mm later on after the 80e swap. he is only running 10 psi for now.
    for build info
    I would expect no less than the GO BIG or GO HOME attitude from someone related to you Mic. Good looking setup.
    Sep 2010
    Nice, good to see it runs in the blood, can't wait to my boys are older so they can have trucks.
    2007 RC Silverado aka ?
    1998 Trans AM aka Red Dragon
    Looks good, I need to convince my Dad on 3 things still. Not everything needs replaced with a big block, computers and fuel injection are not the devil and turbos don't just belong on diseasels.
    yeah, the early model Scorpions were prone to failure at the pushrod cup. I had a set fail, thought an injector crapped the bed but it was a rocker not rocking. They stood by their lifetime warranty even though I was not the original purchaser.
    Oct 2007
    Bandera, TX
    Good to hear
    for build info
