Results 1 to 10 of 89
Thread: Building Iron LS1
    Mar 2010
    Paris, TX
    Building Iron LS1
    Since the motor in my truck is questionable at the moment. Has had metal shavings on drain plug magnet last three oil changes. More every time I change the oil. I have decided to build an Iron Block LS1. Most of the parts are here and I decided to start a build thread. Looking at 11:1 CR with 8.8DCR and a quench distance of 0.030. I know that is on the limit of pump gas but I would like to run e85 once it is available in my area.
    5.3 Block Bored To Fit Stock LS1 Pistons
    Ported Oil Galleys In Back Of Block and Oil Pan
    Stock Crank Cut .010 On Rods And Mains Due To Lifter Failure In Donor Motor
    ARP Rod Bolts
    Clevite Bearings
    Recondition Stock LS1 Rods
    New Gm Stock LS1 Pistons
    Ported (By Me) Stock 706 Heads
    Comp Cams 219/227 .607/.614 Installed 6°Retarded To Keep DCR In Range
    Comp Cams New Revised 918's
    LS7 Lifters
    Comp Cams 7.4 Pushrods
    Melling Oil Pump High Volume Thinking Standard Pressure Spring Come With Both Springs
    42# Delphi Injectors
    Stock Ported Intake and Throttle Body
    Keeping My EBay Headers
    Running Trailblazer Stall For Now
    I am also going to rebuild my transmission while I have my current motor out for the swap. Let me know what you all think of the parts and what power it will make.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Mar 2010
    Paris, TX
    Block Ready For Machine Shop
    Subscribed. Good luck with the build
    Rockwall, TX
    Subscribed would like to know how hard this would be have a donnor short block 5.3 i bought for 100 bucks
    Mar 2010
    Paris, TX
    The hardest part so far was figuring out the compression with ls1 rotating assembly and 5.3 heads. Then picking out the right cam to get a decent dcr. Now I am just waiting on the machine shop.
    Mar 2010
    Paris, TX
    Got the block and crank back form machine shop. Now I have started porting my heads. Head still needs to be cartridge rolled a lot in this pic. Hoping the higher gas prices will cause us to get a E85 station soon. If E85 becomes available around here I will put the cam in strait up for a DCR of 9.3.
    I see you have factory rockers. Did you put the Comp bearing kit in them? If not, I'd sure recommend pulling them back out and replacing the factory bearing with the Comp kit.
    Looks like it coming along nicely. Keep us updated.
    Mar 2010
    Paris, TX
    I did not put the Comp bearing kit in them. Probably going to try to get the tuning issues work out that I am having right now. Then in a month or so buy a nice set of roller rockers.
    nice work, what size injectors are you using?
    Mar 2010
    Paris, TX
    42lb injectors that came with a Roush TVS 1900 kit ID# 28158835. However, I am having some tuning issues since they did not come with any data. It seems run rich or lean with no amount of tuning able to get it in the middle.
