Results 1 to 10 of 12
Thread: In-tank fuel hose
    In-tank fuel hose
    Okay, getting ready to do twin pumps in the tank and want to see what all hose types you guys have had success with. I will be doing 3/8" hose between the pump and the tank mounting plate on barb fittings. I know there is a hose made by Gates PN 27097 and its about $28 a linear foot. I would need about a foot of the hose to go between each pump outlet and the tank, including a loop for the assembly to compress in the tank. I've used fuel injection quality rubber hose successfully many times. So, what are you guys using?
    I've had good luck with Napa's high pressure fuel hose. It's rubber and 5/16 I believe. It's like 9$ a foot. The only issue is when you do the loop it tends to kink. It isn't very flexy.
    Pittsburgh, PA
    i used my earls black hose. i had it so i used it and havent had any issues with it. especially now with it being submerged in corn
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    The black braided Earls hose with the teflon liner?
    Are you going to run 160 lb injectors to run alcohol?
    Pittsburgh, PA
    i was planning on using the 103lb injectors once i setup the fuel system to handle the power. Right now i have 60s with 68psi base pressure and dual meth nozzles to help with the fueling. yes the earls black braided, its been in the tank now over 2 yrs without any deteriation
    412 Motorsports
    Jan 2010
    Cedar Park
    I have 300 psi blue hose in my tank hooked up to my walbro 255. I had 100psi hose burst twice. Also using stainless steel clamps.
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Plainfield, IL
    the 'fuel injection' hose is not rated to be submerged. It will start to deteriorate after a year or two.
    Napa sells the good stuff for about $30 a foot as mentioned. I talked to a few suppliers of stainless braided line, and they said NOT to use it. All recommended the blue line-loc hose. Can usually be had for 5-6 a foot.
    I have had really good luck with this ebay seller, and he seems to be the cheapest on line-loc and braided hoses
    http://cgi.ebay.com/ebaymotors/6-Pus...Q5fCarQ5fParts
    Oct 2009
    Seattle, WA
    Hmmmm. Doesn't say anywhere that the blue hose is submerible.
    2003 GMC K1500 ECSB running an Iron 383 Stroker ......
