Results 1 to 10 of 14
Thread: plug wire diffrence
    verona, virgina
    plug wire diffrence
    I changed the plugs in my 03 yukon today and one of the wires pulled apart so I stole one off of the 01 5.3 I have that to swap into my thrdgen and its short like iits barely cliped on the coil. Was there a diffrence in length for plug wires for thses years? The wire fit on the 01 motor fine.
    03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
    92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
    86 trans am: lm7 hot cam th350 3500 stall
    Plainfield, IL
    99-02 are about an inch shorter. the cars were even shorter then that.
    i run 03 wires on everything, like having the extra room to work with.
    verona, virgina
    Well looks like I'm gona head to the parts store in the morning and see if I can pick up a decent set of wires. I can't tell if the plugs fixed my mis or not. At first I thought so then it started idling rough again after 30mins or so but it could be that short plg wire not getting good connection or I didn't get one snapped on good enough. :/
    Plainfield, IL
    i know at AZ, the wires for the 03's are actually like 20 cheaper then for the 02's. Either should work though. I don't think there's any actual difference in the motors. I actually have 99-02 wires on mine now, they are tight, but fit.
    Might be the coil itself. might wanna swap it and see if that helps before buying wires.
    verona, virgina
    Well one ill have to buy some wires regardless since now the motor I'm using for my swap is missing a wire and it bothers me knowing I have a missmatched wire on my yukon lol. Another thing is idk which coil could be at fault. I kept all the plugs and numbered them so I know where they came out ill post pictures of them when I get off work. I didn't know what the firing order for a lsx motor was right off so I numbered them like a old sbc when I pulled each one. The driverside plugs had much more soot than the pass side plugs. I had also started blowing black smoke since this code came up and with it idling over snow the snow would get covered with soot. After I changed the plugs out today it seemed to start easier and idle smoother especialy after I let it warm up then reved the snot outa it a few times and covered the snow in my front yard with soot!
    Plainfield, IL
    each coil is above each cylinder... the order doesn't really matter
    if you're getting a po300, its random misfire, probably not any particular plug/wire/coil.
    If its a Po30# that cylinder has mis. (be it plug/wire/coil). I'd do plugs/wires first. Especially with your mileage. If you still have a light, and it's a specific cylinder try the coil. Could also be an injector, thought kind of unlikely.
    check your pcv, if that year still has one. I checked my moms other day, and it was missing the check valve...explains why her truck has been going thru oil between changes. That's only thing I can really think of that would cause "soot" unless you accidentally put diesel in it
    Sounds like an o2 sensor crapped the bed.
    verona, virgina
    Found a lose plug wire last night fixed it ans still smokes black under throttle. Codes are p0300 and p0131 pre plug change going again now to get them checked again.
    verona, virgina
    Getting p0171 now also
    Jun 2010
    baxley,ga
    p0171 is system to lean bank 1 i think.check for vacuum leaks or dirty maf
    04 rcsb forged 347
