Thread: 4.8 to 5.3 ?
    4.8 to 5.3 ?
    So i was just lookin on the internet tryin for find the most powerful 4.8 out there but i stumbled over something. i was lookin on wikipedia and it said the bore on a 4.8 an a 5.3 is the same. but the 5.3 had a longer stroke. so dose this mean all you have to do to get a 5.3 it put a crank an some rods in it? here the link. http://en.wikipedia.org/wiki/GM_LS_engine
    1999 4.8 ECSB Z71 Built 4l60e, Straight Pipes Cats only, Redneck Air, TB Bypass,16in American Racing Ventures Wraped in Mastcraft AT 285/75R16 5% all around with 35% on the Full Windshield
    Coming Soon-Efi live tune, Nos,Turbo System, Cam
    The Garage
    You're on the right track. You'd just need the 5.3 crank, rods and pistons. 5.3L uses dished pistons where the 4.8L uses flat-tops. I have heard of people using 4.8L pistons to up the compression on a 5.3L but I always wondered what it would do for valve clearance - especially with a higher-lift cam.
    Houston
    Quote Originally Posted by jetmech View Post
    i would be more worried about piston pin placement and not the flat top issue. If the pin is in the same place then id run the 4.8 piston on a 5.3 rod, also crank and rods can be 5.3, 5.7, 6.0 ect...
    Broken Bow, OK
    Doesn't the L33 have the same part number pistons as the 4.8? Pretty sure they do, so the pin would be in the same place.
    Jun 2009
    Washington DC
    L33 uses the 4.8 flattops and has a sligthly higher c/r
    Houston
    see there you go, run the 4.8 piston then, i have a set if anyone needs them
