Results 1 to 10 of 10
Thread: here is the first start hopfully not the last
    Jul 2009
    Brownfield tx
    it busted right off after i got fuel to the injectors
    Jul 2009
    Brownfield tx
    <object width="400" height="300" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/144795935558248" /><embed src="http://www.facebook.com/v/144795935558248" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="300"></embed></object> maby this will work
    Jul 2009
    Brownfield tx
    nope just have to wait on youtube to finish processing
    Jul 2009
    Brownfield tx
    ok it works now you can see the clip
    nice!!! very nice when things go well, is it all stock?
    Simple: 408 on steroids!
    single digits coming soon!
    Jul 2009
    Brownfield tx
    yea for now but 228r is in the works
    For starters, the fuel pump needs fuel on it to prevent overheating. I'd put more fuel in it before trying to over-do the diagnostics. Also make sure it has the proper fuel pressure when it dies. Another thing that happens is if the water temp sensor sees too much heat, such as from steam, it will put the computer in limp mode and shut off half the cylinders from firing and use raw fuel to cool the engine. I'm not sure on the internal programming logic as if it randomly rotates which cylinders it shuts off or just does specific cylinders.
    Jul 2009
    Brownfield tx
    red heart beat that makes alot of sense caus it kinda sounds like it quits hitting on all cylinders like the puter is doing it and even though i was circulating Im sure that the engine is still trying to burp some air out caus every once in awhile the water tank would start riseing and running over when i killed the engine it went down to nearly empty, also not to mention when the engine was shipped to me the temp sensor was broke off, so i replaced it they had two listed one was 10 bucks the other was 27 bucks the guys at napa said that the 10 dollar one went in the front of the head i hope i got the right one, also this thing did the very same thing the first time i started it and i could not get the water circulating caus my water bottle was mounted a little to low and i did not have the block full of water, although it happende sooner. witch makes sense . it idles with out missing a beat for a long time the boom all of a sudden the starts sputtering and tries to die. but there is no mechanical noise it just sounds like it quits hitten on all 8
