Results 1 to 10 of 10
Thread: Request help identifying non-ECM wire in '89 305
    May 2010
    Hillsboro, OR
    Apparently my friend (really, it wasn't me) was a little hasty in disconnecting wires from the engine and we're trying to find out what the wire is. Coming from the bulkhead connector on the driver's side is a purple wire that we can't ID. I have the ECM wiring that shows O2 and MAP sensor wires are purple, but this wire didn't go to the ECM.
    thanks
    -gl18rider
    if it is a large gauge purple wire it goes to the starter solenoid.
    May 2010
    Hillsboro, OR
    I guess there are 2 purple wires in the convenience block. We have the starter solenoid wire identified. It's the other we're not sure of. From the inside of the truck, it would be in the upper left of the lower block. Does that help?
    thanks for checking.
    Oct 2008
    Tennessee
    I have Chilton manual that show 2 purple wires from ECM. A11 to Map Sensor and D7 to Oxygen Sensor.
    Jun 2010
    I think one should be the TCC brake switch wire.
    May 2010
    Hillsboro, OR
    Old Nash: Yep, I have those figured. There are 2 others going into the convenience block on the drivers side. 1 is the starter solenoid, and the other is ??
    classic79: TCC? What's that?
    Thanks for the help guys. This is a great forum.
    -gl18rider
