Thread: Radiator trans line fitting?
    Jul 2010
    Well I'm plugging right along on my 5.3L swap. About to order everything to make trans and fuel lines.
    TCI website says 1/4" NPT for the 4L60E. I read that's not entirely correct but it will work?
    What size does the radiator need? I need to get some adapters so I can run -6AN hose ends.
    This is for a typical radiator in a 1993 C1500.
    Thanks.
    Aug 2009
    At the transmission you will want 1/4" NPSM and for the radiator will be an inverted flare fitting, i believe mine was 5/8", but i used a 32" radiator out of a 98 when i did my swap on my 93. IIRC you can measure this type of fitting by the OD of the fitting (EDIT: i meant across the threads) on your existing lines going into the radiator. You may want to use 45* and 90* for the AN hose ends at the transmission and radiator as it will help for routing.
    Jul 2010
    Quote Originally Posted by rufus39 View Post
    Awesome. I just did a search on Summit and they have some various pairs of -6AN to 1/4" NPSM adapters listed. I'll measure my radiator. I too read later last night that it may have been 5/8 inverted flare fittings. Ya, I planned on used some various angled hose ends to make the hoses route nicely.
    Ugh, too bad I'm looking at over $200 in fittings and hose to plumb fuel and trans fluid to this thing
    Aug 2009
    Quote Originally Posted by SimpleGreen View Post
    same boat dude...i thought it was going to be a 'neat' idea...well it was neat...neat and expensive, haha
