Results 1 to 10 of 28
Thread: ALL transmission codes on??? need help
    Oct 2009
    Katy ,Texas
    well i have my check engine light on, read the codes and they are all transmission codes,its working fine and i even checked the connections on the tranny and all are good.
    there are 4 codes.
    1- tourque converter clutch circit malfunction
    2-shift solinoid B electrical
    3-shift/timing solinoid malfunction
    4-tourque converter,clutch pressure control soilinoid control circut open
    i disconnected my battery and reset the computer but it came back on after like 45 min of driving? i didnt clear them ,just disconected my battery. any input?? its got a shift kit in it also and kicks super hard on first to second ,when i reset the battery it still shifted hard from first to second but not like it use to wich i liked. just a little more info.
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
    Jun 2010
    West Texas
    Just a thought, but alot of times the ignition switch, which powers the trannys on these trucks, will build up resistance over time and tend to fail to supply power to the tranny. This will cause electrical problems in the tranny.
    RUN WAT U BRUNG!!!!
    Racoon Twp., PA
    2013 CC 5.3
    81 C10 LS1 project
    Oct 2009
    Katy ,Texas
    hmm how would i check to make sure it is the ignition switch? i have a feeling it is because when i first installed my turbo timer i tapped into the wrong wire for ignition 2 and it was acting funny . switched the wires two days later and now it works fine. maybe it messed up something
    Nelson custom tune
    42LB injectors
    Jun 2010
    West Texas
    You would have to take it out and use an ohmeter to check for resistance.
    RUN WAT U BRUNG!!!!
    Dec 2008
    South Carolina
    check the pink wire at the trans harness to see if it has voltage. I believe it is pin E in the plug for the trans. The wire is coming from the IGN O fuse in the fuse block inside the driver side door. that is the power supply for the trans electrical. I had the same problem you did, same codes and everything. so i just spliced in that pink wire just after the fuse at the fuse block and ran a new wire down to the trans harness and spliced it in. I dont think mine was the igntion switch tho cause when i ohmed the wire from trans to fuse block it read OL which means it was either cut/pinched/frayed.
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Try putting 12v to the pink trans power wire straight from the fuse block or battery with a fused link. Clear the codes and drive it around and see if the codes come back. The loss of 12v from the steering column would be an intermittent problem sometimes.
    Dec 2008
    South Carolina
    wouldn't loss of power to the trans from the ignition cause the trans to act up? he says the trans is working fine so im confused..
    Depends if the power loss is intermitant or a hard failure
    Could be a bad pcm ground or broken ground wire. Tug on the grounds and see if the insulation stretches.
    Oct 2009
    Katy ,Texas
    ill gve it another look at later tonight and see if that helps, if not ill just use a jumper wire and see if it does anything
    Nelson custom tune
    42LB injectors
